Old 25-07-2005, 09:11 PM   #1 (permalink)
Default NO "Open With" on right click! Pls Help me
When I right click i can't see 'Open With' option. please help me out with this
well to be more precise, i'm using Windows ME.
my problem is
if i right click on an HTML source file i wanna see something like this
open with -> notepad
HTML-kit
Choose program.
right now i don't have system mechanic but will defly try that.
Radhika is offline
Old 25-07-2005, 09:13 PM   #2 (permalink)
siriusb's Avatar
Try holding the SHIFT key while right-clicking.
Which OS? If XP, did u lose this option suddenly?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 25-07-2005, 09:18 PM   #3 (permalink)
Thanks for ur suggestion! but it doesn't solve the problem! i want to see a list of programs under open with. it's not giving me any options
Radhika is offline
Old 25-07-2005, 09:22 PM   #4 (permalink)
sba
Operating System and type of file u r trying to open?
sba is offline
Old 25-07-2005, 10:19 PM   #5 (permalink)
q3_abhi's Avatar
Hey use a software like System Mechanic or Winboost . There is an option named "Show Open With" or something like that. This can solve ur problem.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 26-07-2005, 12:15 AM   #6 (permalink)
Radhika try this:
Restore "Open With" on the Right Click
Post ur reply once tried.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 26-07-2005, 12:53 PM   #7 (permalink)
tuxfan's Avatar
rajas has suggested registry changes. Desist from it if you are not an experienced user.
Just select a file. Now hold down the shift key when you right click. That will give you an option of "Open With"
tuxfan is offline
Old 26-07-2005, 01:24 PM   #8 (permalink)
siriusb's Avatar
It's already been sugessted and was reported unhelpful.
@Radhika
See if any of the symptoms mentioned here, here and here apply to you and follow the appropriate remedial steps if they do. And pray tell us your OS and the detail of ur problem.
siriusb is offline
Old 26-07-2005, 10:30 PM   #9 (permalink)
hack expert's Avatar
well OS not mentioned but u can always try the softwares mentioned by q3_abhi winboost is a good one
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 27-07-2005, 11:20 AM   #10 (permalink)
tuxfan's Avatar
There is a difference between shift + right click and select + shift + right click, at least in Win98.
You suggested the former, I suggested the later :roll:
tuxfan is offline
