Old 25-07-2005, 05:23 PM   #1 (permalink)
tech_cheetah's Avatar
Default sub woofer posing health problems :-(
hi friends ! i have just bought intex 2600W subwoofers(with 4 satellite speakers).The quality of music is superb,but i m having some other problems... even at normal volume(ie. at which one can listen all the instruments n frequencies in the music) i start feeling pain in my chest(probably near heart) due to the bass beats. moreover i found it difficult to sit infront of the speakers bcoz the ears start feeling heavy after some time.so i had to turn their faces the opposite direction.believe me i have kept the volume just at bare minimum to hear the songs with all quality n the bass control is also at minimum.I m feeling as if i have wasted my money n switch back to my 400W speakers. Is there anything wrong with the subwoofer ? what should i do.. Go to doctor
tech_cheetah is offline
Old 25-07-2005, 05:43 PM   #2 (permalink)
Netjunkie's Avatar
Well this is the first time i am hearing that subwoofers cause chest pain, I heard of discomfort to the ears before.
First consult the doctor. Ear problem could be because of improper positioning of the woofer or bad room acoustics.
Anyway lets wait for the others to post.
Netjunkie is offline
Old 25-07-2005, 07:05 PM   #3 (permalink)
U must be keeping your sub-woofer on the desk / near the monitor or PC . Ideally it should be placed on the floor. No ammount of sound can cause what u are saying ! All u are feeling is the bass effect in the chest cavity , which everyone can feel. Besides Altec Lansing is far better than intex
Huzefa is offline
Old 25-07-2005, 09:07 PM   #4 (permalink)
siriusb's Avatar
Looks like the sub-w0ofer's diaphram and ur diaphram are in resonance
Or maybe ur heart is not in it
No need to throw those good speakers out. Just find the bass control on the speaker or in Volume Properties and reduce it.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 25-07-2005, 09:17 PM   #5 (permalink)
ROFL lol siriusb
Huzefa is offline
Old 25-07-2005, 11:22 PM   #6 (permalink)
Do you by any chance have a pacemaker? Because a non-magnetically shielded set of speakers would play havoc with a pacemaker.
drvarunmehta is offline
Old 26-07-2005, 09:19 AM   #7 (permalink)
MVP in VC++
Hey try to keep the Sub-woofer somewhere bit far from u r system. Don't keep it on u r system etc...
cvvikram is offline
Old 26-07-2005, 12:33 PM   #8 (permalink)
well i m keeping the woofer below the desk n now i m planning to place the satellite speakers high on the wall at the four corners of the room..may b that will reduce the strain on ears a bit and solve the problem.. lets c
Be honest . By that way u can be sure that the world is short of atleast one rascal.
Old 26-07-2005, 02:37 PM   #9 (permalink)
bharat_r's Avatar
Woofers & Sub woofers are ment to do that.
They did what they are supossed to do
bharat_r is offline
Old 29-07-2005, 04:55 PM   #10 (permalink)
the problem is solved with the 4 satellite speakers at the four corners high up on the wall.. i bet this is the best way to obtain the surround sound configuration without paining ur ears..
Old 29-07-2005, 07:17 PM   #11 (permalink)
siriusb's Avatar
Just what I wanted to say after noticing that u had the speakers in front of you. It was the directional high freq sound from the satellites and not the non-directional low frqs from the sub.Placing them farther is the correct solution. But some fellas I know often turn the satellites away from the general direction of their head to avoid high frq sounds because they have small rooms. Good work finding it out urself.
siriusb is offline
Old 30-07-2005, 08:44 AM   #12 (permalink)
Let the music play.....
djmykey's Avatar
Dood I use an Altec and believe me when sometimes I get the rush I keep the sub in front of me for 5 - seconds and play some damn bass music and it almost give me vibrations so dood dont do something crazy like me just keep all da spks where it is supposed to be and enjoy da music.
djmykey is offline
Old 13-08-2005, 12:50 AM   #13 (permalink)
CCIE# 20863
One of my friend had put his subwoofer of altec lansing avs 251 on desk. Once he put a glass bowl in front of it. When he started playing metallica on his sub-woofer with volume set to abt 40%, the bowl broke into pieces....
Now the friend uses headphones for listenign to music...
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 13-08-2005, 01:59 AM   #14 (permalink)
Wire muncher!
infra_red_dude's Avatar
dude, gade murde kyon ukhad rahe ho?? (meaning, why are u diggin old topics??)
infra_red_dude is online now
Old 13-08-2005, 08:39 PM   #15 (permalink)
I too have heard people complain of this , although your case is bizarre
Firstly, go to a good search engine and search for guidelines on how to position your speaker correctly.
If the pain is too much then keep them on a shelf as someone rightly mentioned.
Do visit the doc.If you have a medical history of diaphragm probs then you need to consult him.
If your speaker is within the warranty period, Get it checked at an authorised test centre. Such problems may be caused by faulty diaphragms.
Reach for the stars \'cuz even if you miss, you\'ll get to the clouds\"
srijan007 is offline
