Hi,
Try this. Right-click on the Speaker icon in System Tray, and click "Open Volume Controls". Then, here move the sliders to maximum position for Volume Control, Wave Out, CD Audio and Mic options. Also, make sure that none of these options are Muted or Deselectd.
If you dont have the Speaker icon in System Tray, then go to Control Panel, and double-click on "Multimedia" applet. Then select "Show volume control on the Taslbar". After this, you will get the Speaker icon.
http://swatrant.blogspot.com/
