Old 24-07-2005, 11:33 AM   #1 (permalink)
Traceur
zegulas's Avatar
Default Which PC???
I hav a budget of Rs.25000, and want the best config for dat. And also which PC would i get better in dat range a branded one or assembeled.
Plz hurry up ur ans!!!
And also give me the config u think is best.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 24-07-2005, 01:26 PM   #2 (permalink)
sidewinder's Avatar
pref amd 64 2800+,msi rs 480 il2 mobo,512 mb ddr 400,17" monnd so on.discussed many times here..plz search
Bombina rocks
sidewinder is offline
Old 24-07-2005, 08:33 PM   #3 (permalink)
Netjunkie's Avatar
Go for an Assembled PC. For 25k i dont think you can get a good branded one. Search the forum & you can find come real good configs.
Netjunkie is offline
Old 24-07-2005, 08:37 PM   #4 (permalink)
Netjunkie's Avatar
I tried to search for you but getting this error
Could not obtain matched posts list
DEBUG MODE
SQL Error : 1030 Got error 134 from table handler
SELECT m.post_id FROM phpbb_search_wordlist w, phpbb_search_wordmatch m WHERE w.word_text LIKE 'config' AND m.word_id = w.word_id AND w.word_common <> 1
Line : 308
File : /usr/local/php4/htdocs/thinkdigit/forum/search.php
Old 24-07-2005, 08:49 PM   #5 (permalink)
I think at that price there are good Compaq PC's available.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 24-07-2005, 09:09 PM   #6 (permalink)
vignesh's Avatar
You can choose a good config based on what you are going to actually use it for ?
vignesh is offline
Old 25-07-2005, 11:53 AM   #7 (permalink)
i think u can get best assembled pc for rs 25000.
go for amd athelon PC . Its best.
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
Old 25-07-2005, 10:47 PM   #8 (permalink)
q3_abhi's Avatar
Go for a PC which will suite ur needs. If it is required for office work, then u can get a good PC for this purpose at the current budget.
If u want the PC for gaming or any heavy mutlimedia applications then u will have to spend more to get a good one.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
