Old 23-07-2005, 10:43 PM   #1 (permalink)
Default Customize Desktop missing from right click on desktop
I am facing this peculiar problem
Was installing Sonic Sounde Forge 6.0 and after that I saw that my "My Computer" icon from the desktop went missing. No biggie, just right click on the desktop and select properties, but when I did that I found this
Can't get the My Computer Icon, can't change the wallpaper, just 2 options Shown, Screensaver and Settings !!!
What happened to rest of the options
Any ideas how to bring it back to the original self.
OS - Windows XP SP2
Appreciate all the help that can be given here
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 23-07-2005, 11:33 PM   #2 (permalink)
swatkat's Avatar
Open NotePad, and copy the contents of the below "Code" box:-
regedit /e test1.txt "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies"
regedit /e test2.txt "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies"
copy test1.txt + test2.txt = info.txt
del test1.txt
del test2.txt
Go to File Menu > Save As, and save the file with the name Test.bat and exit from NotePad.
Double-Click on the file Test.bat, a small DOS type window should open and close immediately.
After this, there would be a file called Info.txt in the same location where Test.bat was present. Open the Info.txt and post it's contents here.
http://swatrant.blogspot.com/
swatkat is offline
Old 23-07-2005, 11:36 PM   #3 (permalink)
alib_i's Avatar
i hope you have windows xp professional
go to start -> run -> type gpedit.msc and enter
go to Computer config -> user config -> admin templates
-> control panel -> display
disable following entries
# hide appereance and themes tab
# hide desktop tab
in display subfolder disable :: remove theme option
alibi
-Metallica
alib_i is offline
Old 23-07-2005, 11:44 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
Navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\System
If there is a DWoRD Value such "NoDispScrSavPage" with a data value of 1 this will disable the screen saver tab. Change the value to 0 or delete it to see the tab again.
see MS data Base..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-07-2005, 12:47 PM   #5 (permalink)
Thanx swatkat, alib_i and saurav_cheeta.
Took alib_i's advice and everything is back to normal.
Thanx for the help guys, appreciate it, U rock !!!!
