photo to vcd creation hassle, plssssssss help!!!!!!!!
i have tried to create a vcd from a few photos. i have used 'photo2vcd studio' and 'iphoto'. i have followed each and every step from compilation to burning the vcd. but my only problem is that after its ready it is not played in any of the vcd players in my house but it plays fine in my computer with all the transition effects. i am feeling helpless. somebody please me.
Hi,
You can use Slide Show Movie Maker ( a freeware ) to create AVI files from photos. Then you can use normal CD burning softwares to create VCDs out of it.
If you are using Windows XP, then you can use Windows Movie Maker itself.
There are many powerful Photo to VCD/DVD softwares are available.
Here is a small list:
01. Ulead DVD Movie factory 4
02. Ulead CD& DVD Picture Show 3
03. Nero Vision Express 3
04. Nero Photoshow Elite 1.01
05. Able Photo Slide Show 1.6
06. 1st Photo To DVD Slideshow Burner 2.58
07. Photodex Proshow Gold 2.5
08. Roxio Easy Media Creator 7.5
09. Microsoft Photo Story 3
10. Photo2DVD Studio 4.2
11. SlideShow pro 9.76
Out of these the most powerful is Photodex Proshow Gold 2.5
It has many transitions effects than any others.
Also the result can be trusted and will be played in most VCD players.
You can also try SlideShow pro 9.76. :roll:
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
