Old 22-07-2005, 05:25 PM   #1 (permalink)
Default SATA HDD identifiaction mark????
HI,
CAN ANYONE PLS GUIDE ME TO DISTIGUISH BETWEEN NORMAL ATA (PATA) AND SATA HDD. AS AM ON TO SATA HDD, I HAVE TO MAKE SURE THAT I AM REALLY GETTING SATA.
AS PER I KNOW, SATA HAS SERIAL CABLE INTERFACE. IS THIS CLEARLY SEEN BEHIND THE HDD OR THAT IT HAS BOTH SERIAL AND PARALLEL INTERFACE AT ITS BACK.
HLP TO SORT THIS OUT.
AKEN
taken is offline
Old 22-07-2005, 05:52 PM   #2 (permalink)
A SATA HDD won't have both SATA and PATA connectors. It will clearly be written on the HDD whether it is SATA or not. Or look up the model no. on the internet to make sure.
drvarunmehta is offline
Old 22-07-2005, 06:25 PM   #3 (permalink)
siriusb's Avatar
PATA has the charactesitic 40 or so pins and also a 4pin molex power connector.
A SATA doesn't have both these pins sticking out. It's connectors are rather small and thin.
And, ofcourse, the label will clearly read "SATA" hd.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-07-2005, 02:55 PM   #4 (permalink)
thanks a lot. i can now go and get the same
taken is offline
