Old 22-07-2005, 01:46 AM   #1 (permalink)
Default CD-ROM Problem
Today I have found that my CD ROM is getting in and comes out autometically. I restarted machine for several times. But this cannot solve my problem. My CD ROM worked fine yesterday. Can you tell me the problem and its solution?
M K Paul
mkpaul is offline
Old 22-07-2005, 06:04 AM   #2 (permalink)
sidewinder's Avatar
it just might be a very old virus.make sure u hav a av software running.
Bombina rocks
sidewinder is offline
Old 22-07-2005, 06:10 AM   #3 (permalink)
q3_abhi's Avatar
May be a virus as said by Sidewinder. But even some softwares can do this.
Check if u have any CD eject n related sotware.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 22-07-2005, 01:32 PM   #4 (permalink)
siriusb's Avatar
Here's a question similar to the one asked:
http://www.thinkdigit.com/forum/viewtopic.php?t=24555
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 22-07-2005, 07:22 PM   #5 (permalink)
hack expert's Avatar
i had such a problem with my samsung cd rom but it was not due to some virus some part inside my cd rom had broken n dat was the reason
well i had to replace it donno about u
does it come out randomly or continuosly ????
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 22-07-2005, 10:31 PM   #6 (permalink)
abhishekkulkarni's Avatar
Guess Samsung Drives are famous for all the wrong reasons these days.....
Is yours a Samsung too?
If it is you need not worry.Coz even though their Optical Drives su*k , their warranty & service rocks.
It must be probably a tray motor problem.
Just get it repaired or replaced.
May the source be with you ..
abhishekkulkarni is offline
