Old 21-07-2005, 08:35 PM   #1 (permalink)
abhishek_sharma's Avatar
Default how much wattage power supply do i need
i have a pIII 1GHz processor with intel original motherboard, i have a dvd rom, 1 cd writer, a 80 gb hard disk and a geforce 4000 mx graphics card.
i have a power supply with 250 watt rating from kobian. is it sufficient for my config, i have been experiencing problems of late.
Problems include suddenly turning off the computer, while the motherboard's led keeps glowing. another problem is that the cd writer is detected by the os, but no cd gets get detected on insertion.
plz help!!! :roll:
abhishek_sharma is offline
Old 21-07-2005, 09:28 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hmm... doesnt seem that the problems u r experiencing are due to ur SMPS! Anyway, 250 Watts is a little on the lower side . If buying a new SMPS, go for at lest 350 Watts though 300 Watts should be enough. But plan for the future!!!
kalpik is offline
Old 22-07-2005, 02:09 AM   #3 (permalink)
i would recommend 300Watts minimum !!! Hey Check the Wires if there r connected properly !!! And Get ur Cd- writer Lens Cleaned Could be that the lens is unclean !!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 22-07-2005, 06:16 AM   #4 (permalink)
q3_abhi's Avatar
Default Re: how much wattage power supply do i need
plz help!!! :roll:
Front panel LED connections are not proper. See the motherboard's manual n fix them correctly.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 22-07-2005, 11:22 AM   #5 (permalink)
MVP in VC++
For u r config i think that is enough most probably the SMPS wires are not fixed to MOBO properly ...
cvvikram is offline
Old 22-07-2005, 09:46 PM   #6 (permalink)
Experianced the same problem once. Turned out to be faulty SMPS.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
