On Web forums, the subject header is your golden opportunity to attract qualified experts' attention in around 50 characters or fewer.
Don't waste it on babble like “Please help me� (let alone “PLEASE HELP ME!!!!�; messages with subjects like that get discarded by reflex). Don't try to impress us with the depth of your anguish; use the space for a super-concise problem description instead.
A good convention for subject headers, used by many tech support organizations, is “object - deviation�. The “object� part specifies what thing or group of things is having a problem, and the “deviation� part describes the deviation from expected behavior.
Stupid:
HELP! Video doesn't work properly on my laptop!
Smart:
XFree86 4.1 misshapen mouse cursor, Fooware MV1005 vid. chipset
Smarter:
XFree86 4.1 mouse cursor on Fooware MV1005 vid. chipset - is misshapen
Be precise and informative about your problem
-> Describe the symptoms of your problem or bug carefully and clearly.
-> Describe the environment in which it occurs (machine, OS, application, whatever).
-> Provide your vendor's distribution and release level (e.g.: “Fedora Core 2�, “Slackware 9.1�, etc.).
-> Describe the research you did to try and understand the problem before you asked the question.
-> Describe the diagnostic steps you took to try and pin down the problem yourself before you asked the question.
-> Describe any recent changes in your computer or software configuration that might be relevant.
Do the best you can to anticipate the questions a hacker will ask, and to answer them in advance in your request for help.
How To Ask Questions The Smart Way
I know there's a sticky on the same subject, but its locked. i request mods to merge this thread to the sticky, i they want.
Source
