I just recovered from a Win XP crash. I had to reinstall all the programs.
& in the installation process I had to reboot my system innumerous times. (Because almost all software require a reboot.) what i want to ask is can somebody help me by telling any software to create customizeable CD for installation. Like the DIGIT Medikit.iso. but they have there own software in it & i wish to have softwares which i daily use. if you have seen the Unofficial 98 SP pack provided with JULY DIGIT. at installation, it provides you with a list of softwares & you can select what all you want & it will install those for you. it can also be seen in Auto patcher.
Also before formatting my hard disk, i had made a DVD containing all my documents, music files, spread sheet & bookmarks using Nero 6.6. in the middle (i think 88 %) it showed error & stopped writing. but when i opened the DVD at that time. it shown all documents. but after formatting my hard disc, now the same DVD shows the name of those documents but no documents can open. PLZ HELP....
