Old 20-07-2005, 04:25 PM   #1 (permalink)
Default CMOS problem
I have two MOBO which use intel 810E chipset. The problem is whenever I start these machines everytime I have to go to the CMOS setup. After resetting the date & time, IDE Configuration and CPU PnP Setup the systems run properly.
why is this happenning? Tell me a solution.
M K Paul
mkpaul is offline
Old 20-07-2005, 05:00 PM   #2 (permalink)
t3h g04t
teknoPhobia's Avatar
Most probably battery
technologically challenged.
teknoPhobia is offline
Old 21-07-2005, 12:47 AM   #3 (permalink)
I have changed the batteries. but the problems are remains.
M K Paul
mkpaul is offline
Old 23-07-2005, 11:09 PM   #4 (permalink)
bukaida's Avatar
Default check the battery connection
check the battery connection. Take the battery and press the clips.Then reinsert the battery.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 24-07-2005, 12:23 AM   #5 (permalink)
hack expert's Avatar
since u say u have changed the batteries maybe the connnection will be loose
also check the jumper setting used to clear the cmos set it to the default position maybe dat`s the prob
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
