Old 20-07-2005, 03:00 PM   #1 (permalink)
slugger's Avatar
Default SOS Recycle Bin missing !!!
I boot up my rig one day and to my utmost horror I found that the recylce bin icon was missing from my windows explorer window. I have Windows 2000 with sp3.
I first went to the folders option and deselected the option of viewing system protected filez. Sure enough the bin was there and I was able to delete filez from there. However, I want it the way it was the way it was before with the icon in the windows explorer window without deselcting the above mentioned option. I had not used any 3p tweaking sw, so can anybody also tell me what it is that I did to suffer such a fate.
slugger is offline
Old 20-07-2005, 04:36 PM   #2 (permalink)
ok
create the shortcut of recycle bin on ur desktop
so simple
rename it
who the hack is this??
mukul is offline
Old 20-07-2005, 05:30 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
use powertoy 'tweak ui for windows'
it can repair the desktop recycle bin icon.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 20-07-2005, 08:07 PM   #4 (permalink)
Just Do It
Charley's Avatar
That'd be better since u have the icon located elsewhere, just right click and create a shortcut and drag it to the Desktop.
Charley is offline
Old 20-07-2005, 10:21 PM   #5 (permalink)
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate the following registry key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\HideDesktopIcons\NewStartPanel
4. In the right pane, right-click the following registry DWORD value, and then click Modify:
{645FF040-5081-101B-9F08-00AA002F954E}
5. In the Value data box, type 0, and then click OK.
No Mercy, No Limits.
theraven is offline
Old 21-07-2005, 11:17 AM   #6 (permalink)
slugger's Avatar
ok
so simple
rename it
I do not want the recylce bin on the desktop, but in the windows explorer window, as it was there before and I have clearly mentioned
By doing what you have said, will I get the recycle bin on my desktop or in my windows explorer window?
slugger is offline
Old 21-07-2005, 04:11 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
by doin that u will get it on the desktop
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-07-2005, 06:04 PM   #8 (permalink)
ok my bad .. i skipped most of ur post .. i followed what the others said ...
so wehre exactly in windows explorer do u wanna see the recycle bin ??
the only place its there is on the desktop ! thats where its present
even in explorer u need to browse to desktop to see it.
or im gettin u wrong somewhere .. so a screenshot would be of gr8 help
theraven is offline
Old 26-07-2005, 11:49 AM   #9 (permalink)
slugger's Avatar
this is where my recylce bin was before it disappeared
slugger is offline
Old 31-07-2005, 11:37 AM   #10 (permalink)
follow the step i gave ... see if it works
cuz if its on the desktop then its there in explorer ..
i know u can see it on desktop after what u did. . but just try it
im sure it'll work
theraven is offline
Old 31-07-2005, 01:21 PM   #11 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Start -> Run, type regedit, goto:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Explorer\MyComputer\NameSpace
Right-click on NameSpace key and select New -> Key and give the name {645FF040-5081-101B-9F08-00AA002F954E} to this key.
Now Recycle Bin should be visible in Windows Explorer.
SIMPLE...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 05-08-2005, 01:05 PM   #12 (permalink)
slugger's Avatar
SIMPLE...
sorry man, ouldn't try out ur soln. the friend of mine who had this problem decided to format his hdd and reinstall the OS (not just a simple reinstall !!!) before i could ge back to him. Hope he screws up his OS again so that I can try out the solns given in the thread
slugger is offline
