19-07-2005, 10:30 PM
IP address change
Hey guys! I need to know whether there is a software available which can change the IP address of the computer on which it is installed. The software should be able to change the IP address of the computer as per need.
Thanks!
19-07-2005, 10:45 PM
firstly wats ur connection type if its dialup the ip address is dynamically alloted every time u can check the ip at sites like
www.ipaddressworld.com
if ur on a network then u dont need any softwares go in control pannel
network connections \propeties in dat click on TCP\IP properties
uncheck the dialogue box [obtain ip automatically]
and the below u can specify the ip u want
donno any software dat can do it well wait for some others to post
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
20-07-2005, 09:45 PM
I use an airtel broadband connection 256 kbps.
20-07-2005, 09:50 PM
Imho you have a dynamic[changes when you disconnect & connect again] IP address issued by the ISP Airtel.
What you are asking for is not possible.The only way as I see it is passing through a anonymous proxy server which is not only insecure but I may describe it as STUPID !
May I know why you want to change the IP address given by your ISP?
www.Oobertech.net
20-07-2005, 10:21 PM
As pointed out, proxies are the only way to change your global ip in any sense. Proxies in general will slow your net connection. So, unless you want to change your identity for some specific task, proxies aren't the answer.
BTW, are u using the usb modem or nic card for internet? If using nic card, u can change ur lan ip by using hackexpert;s method.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
20-07-2005, 11:45 PM
Senior Member
hi
why change IP address? will it be difficult for others to hack (or do anything illegal) if i change ip address.
and what is ARP spoofing?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
21-07-2005, 12:01 AM
M usin a usb modem for accessing da net. i need to chg my IP address because the download site from where i download all my warez ... recognizes my IP add each time, n i cannot download new software. I have to wait for hell of a long time untill i can download a new ware!
21-07-2005, 12:31 AM
I believe we should end this discussion right here.Warez related queries are not dealt here so please take it elsewhere.
www.Oobertech.net
21-07-2005, 01:31 AM
When the hell did i ask you to help me out wid warez huh?! All i asked as a query was about a software which would enable me to change my IP address. Thats bloody it! All i want as an answer is a no, or a yes with the software name! If you dunno about ... plz dun post! Your being flamboyant at no reason whatsoever!!!!
21-07-2005, 02:35 AM
This comes under hacking activities and so Sourabh should lock this thread.Go and discuss these isues in hacking sites.
21-07-2005, 03:35 AM
Listen dude you may not be asking for warez n stuff but your intent is clearly un-ethical & may give a wrong sense of impression for a new member.
Asking for solutions so that you could continue downloading warez doesnt sound good to me but if other mods are comfortable with it then I'm fine.
Oh if you have read my earlier post then the answer is a simple NO !
www.Oobertech.net
21-07-2005, 12:51 PM
I've been in a similar situation sans warez. For example, some sites won't give you more of a resource in one day or summat.
You can use s/w like wingate and the like. But I prefer to collect a list of proxies from proxyblind.org and proxyelite.org and use them in my browser, one after the other. I am merely pointing you to their sites and not the list. Read about their correct usage first.
21-07-2005, 11:04 PM
Thanks man!
Search this Thread |
