Old 15-09-2004, 12:05 PM   #1 (permalink)
Default progress bar....GONE!!
hi people...i just discovered something missing in my explorer...the progress bar in the bottom is gone....i am unable to understand the cause....any ideas?
hearthacker is offline
Old 15-09-2004, 04:24 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You mean Internet Explorer ..? Reinstallation of IE will help ...
Btw ... Is View > Status Bar is enabled or not ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 17-09-2004, 08:41 PM   #3 (permalink)
Default Progress bar
this usually happens whenever u use ie for more than 10 times(i guess), coz it happened to me and it's fixed now.
thegeeek is offline
Old 18-09-2004, 12:52 PM   #4 (permalink)
View>Status Bar.
Enable it.
Simple things are to simple too understand.
Prashray is offline
