Old 19-07-2005, 01:34 AM   #1 (permalink)
Default Writer problem.
MY sony cd writer has spoilt the last 6 out of 10 cds. It stops writing and it says write error. This is the first time im getting such an error. im using nero. The following is the log which appeares. Please let me know when such errors occour. is it a software problem, hardware problem or the cd problem.
Neville
1A20-0100-0000-1565-4218-3131
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/28/2004 4:51:12 PM
Nero version: 6.6.0.1 (Nero Express)
Recorder: <SONY CD-RW CRX230ED> Version: 4YS1 - HA 1 TA 0 - 6.6.0.1
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <OBVIOUS DVD-ROM MAGIC 62>Version: 6.00 - HA 2 TA 0 - 6.6.0.1
Adapter driver: <obvious> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0411N atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SONY CD-RW CRX230ED atapi Port 1 ID 0 DMA: On
DiskPeripheral : Maxtor 2F040L0 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : OBVIOUS DVD-ROM MAGIC 626.00 obvious Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY CD-RW CRX230ED K: CDRom0
OBVIOUS DVD-ROM MAGIC 62 L: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 55574528 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 366MB (375528kB)
Free physical memory: 114MB (116996kB)
Memory in use : 68 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.7.2005
CD-ROM (ISO)
1:12:55 PM #1 Text 0 File Isodoc.cpp, Line 6165
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
1:12:55 PM #2 Text 0 File Burncd.cpp, Line 2832
SONY CD-RW CRX230ED
Power-Burn activated
1:12:55 PM #3 Text 0 File Reader.cpp, Line 127
Reader running
1:12:55 PM #4 Text 0 File Writer.cpp, Line 122
Writer SONY CD-RW CRX230ED running
1:12:55 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
1:12:55 PM #6 Text 0 File Burncd.cpp, Line 3117
Turn on Track-at-once, using CD-R/RW media
1:12:55 PM #7 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 332982 ( 74:01.57)
1:12:55 PM #8 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
1:12:55 PM #9 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: SONY CD-RW CRX230ED;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
1:12:55 PM #10 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
1:12:55 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 844
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 332983 (332983) = #332983/73:59.58
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 332981 blocks [SONY CD-RW CRX230ED]
1:12:55 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1047
Prepare recorder [SONY CD-RW CRX230ED] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 682256384, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
332983 | lead-out | 1 | 0x00 | 0x41
1:12:55 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1096
Removed 2 run-out blocks from end of track 1. Length: 332983 -> 332981.
1:12:55 PM #14 Phase 24 File dlgbrnst.cpp, Line 1853
Caching of files started
1:12:56 PM #15 Text 0 File Burncd.cpp, Line 4003
Cache writing successful.
1:12:56 PM #16 Phase 25 File dlgbrnst.cpp, Line 1853
Caching of files completed
1:12:56 PM #17 Phase 36 File dlgbrnst.cpp, Line 1853
Burn process started at 40x (6,000 KB/s)
1:12:56 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2497
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
1:12:56 PM #19 Text 0 File Mmc.cpp, Line 20673
Set BUFE: Power-Burn -> ON , SMART-BURN : ON
1:14:15 PM #20 SCSI -1135 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x09830000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x01 0x38 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
1:14:15 PM #21 CDR -1135 File Writer.cpp, Line 311
Write error
1:14:15 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
1:14:15 PM #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
1:14:16 PM #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
SONY CD-RW CRX230ED\H1 T0
1:14:16 PM #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
1:14:16 PM #26 Text 0 File Mmc.cpp, Line 15477
<SONY CD-RW CRX230ED > start Close Session
1:14:38 PM #27 Text 0 File dlgbrnst.cpp, Line 1711
Set remaining time: 0:00,000 (0ms) -> OK
1:14:38 PM #28 Phase 38 File dlgbrnst.cpp, Line 1853
Burn process failed at 40x (6,000 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 12/21/2004 12:07:14 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for rec)
File 'Drivers\obvious.sys': Ver=6.0.0.0, size=74496 bytes, created 2/19/2004 10:39:00 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
nevillle23 is offline
Old 19-07-2005, 08:09 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
I think its a hardware prob, actually a prob wid sony. The lens becomes weak very soon. Even my sony died! But was in warrenty so got it repaired! Hope urs is in warrenty too!
kalpik is offline
Old 19-07-2005, 07:42 PM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
please reinstall the software and the drivers of your cd writer... 8)
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 19-07-2005, 09:56 PM   #4 (permalink)
q3_abhi's Avatar
Re-install the software. If the problem persists check the writer. Formatting n re-installing sometimes can solve the problem (if not a hardware one).
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 20-07-2005, 12:00 PM   #5 (permalink)
vandit's Avatar
what did I say then ? just increasing the no. of posts (247) currently ye ???
vandit is offline
Old 20-07-2005, 12:22 PM   #6 (permalink)
Well as many other ppl said try reinstalling the software and drivers for ur CD writer and then also check ur power cable and Data cable try plugging them out and reconnecting them properly(i.e with ur computer power shutdown :-p ) & also try using a lens cleaner if all this dosent work give ur writer for servicing
cryptid is offline
