Old 18-07-2005, 07:25 PM   #1 (permalink)
Default burning audio cds with WMP10
i have plenty of mp3s on my hdd dat i wud like to covert into .cda files and burn them so dat i can listen to them on my car's cd player (it only plays audio cds)
can i do this with wmp10?
if not, than plz tell me which software to use?
setharsh is offline
Old 18-07-2005, 08:56 PM   #2 (permalink)
hack expert's Avatar
well i donno bout mp10 i think it needs a plugin donno exactly
but u get a wide range of software to suit ur purpose
here`s one
www.audioutilities.com/mp3-to-cd/ mp3-cda-converter-burner.htm
this is one of many on google download i n u good to go
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 18-07-2005, 09:06 PM   #3 (permalink)
swatkat's Avatar
Yuo can use WMP10 to burn CD. Open WMP, click the Copy to CD or Device button in the left pane. Next under Items to copy option box, select the playlist you want to burn to CD (you can also select "All Music", later you can check the songs to be burnt, and uncheck those you dont want), next insert blank CD, and click "Copy" button (which is a red coloured button).
For more help, you can take a look here
You can also use CD burning softwares like Nero, NTI, DeepBurner, CDBurnerXP.
CDBurnerXP is a good and free tool, which is very easy to use. Select the Audio CD option, and select the songs you want to burn, and ,yes!, burn them.
http://swatrant.blogspot.com/
swatkat is offline
