Old 18-07-2005, 04:29 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Partition merge-ing ! ! !
i have winxp sp2 with 80 gb hdd ... partition of c,d,e (10,10,60 gb) ...
wanna merge 1st 2 partitions (10,10) ... as i have installed many softwares on c drive, it is left with very little space ... due 2 which my comp. is running slow ...
have also moved my data on d drive (10 gb) onto my e drive (60 gb)...
now that my 2nd partition is empty, how can i merge these 2 partitions ???
& is it advise-able 2 keep c drive, 20 gb ???
& will my 3rd partition (60 gb) b also affected after re-merging of previous 2 ???
ax3 is offline
Old 18-07-2005, 09:36 PM   #2 (permalink)
swatkat's Avatar
Hi,
You have to use third party softwares like Partition Magic, Disk Director. 7 Tools or Paragon Partition Manager, to merge partitions. There would not be any problems with merging partitions using these softwares, as they will redirect all the refereces/paths to the changed/merged partitions automatically.
http://swatrant.blogspot.com/
swatkat is offline
Old 19-07-2005, 11:23 AM   #3 (permalink)
ax3
ax3's Avatar
any freeware software ...
or wont winxp installation cd do it ???
... W H O T ...
ax3 is offline
Old 19-07-2005, 12:58 PM   #4 (permalink)
swatkat's Avatar
There is one freeware called Ranish Partition Manager, but be careful while using it. ( it's not as user friendly as other commercial softwares )
No, you can not use Windows CD to merge partitions.
swatkat is offline
Old 19-07-2005, 04:01 PM   #5 (permalink)
mariner's Avatar
use partiton magic. safe and easy too.
mariner is offline
Old 20-07-2005, 11:47 AM   #6 (permalink)
ax3
ax3's Avatar
bt its not free ...
still ... will look for the software ...
thanx 4 ur replies ...
... W H O T ...
ax3 is offline
Old 21-07-2005, 12:06 PM   #7 (permalink)
ax3
ax3's Avatar
has partition magic provided in digit cd/dvd ???
... W H O T ...
ax3 is offline
Old 04-08-2005, 04:29 PM   #8 (permalink)
ax3
ax3's Avatar
has digit given Norton Partition Magic ???
... W H O T ...
ax3 is offline
Old 04-08-2005, 05:11 PM   #9 (permalink)
Commander in Chief
QwertyManiac's Avatar
the digit's version of partition magic is like a flash trial , it allows u to use the interface but not to perform any action on it....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-08-2005, 11:23 AM   #10 (permalink)
ax3
ax3's Avatar
... W H O T ...
ax3 is offline
Old 05-08-2005, 03:14 PM   #11 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Yes!
1.) I hv my C: partition of size 4 GB only. Basically it depends upon ur requirements. If u think that u need 20 GB then u can merge both of them without ne worry. 1 thing more if u think that ur C: partition is not big enough for installing s/w, then u can install the s/w on D: drive, no problem will ocuur. So in this case u'll not need to merge both of them.
2.) When u'll merge both 1st & 2nd partitions, the 3rd partition "E:" will become "D:", no other changes.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-08-2005, 11:51 AM   #12 (permalink)
ax3
ax3's Avatar
thanx 4 the reply ...
my c drive is just 10 gb ... as i have many games installed ...
& will have more ... so ...
... W H O T ...
ax3 is offline
