Old 17-07-2005, 11:40 PM   #1 (permalink)
hack expert's Avatar
Default is this file normal or no
there is a file called webproxy.exe in my taskmanager\processe wat is the function of dat file or is it some trojan please help me out
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 17-07-2005, 11:44 PM   #2 (permalink)
siriusb's Avatar
According to this site, webproxy.exe is nothing but a part of Panda antivirus suite. It is very much advisable that u get all the other processes in ur task manager check out at this site:
http://www.processlibrary.com
other such sites would be:
http://www.liutilities.com
http://research.pestpatrol.com
PS: Personally, I don't go to these site manually myself, as I just type the process in question in google and google lists results from these sites on top. I would advise u to do that too.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 18-07-2005, 03:45 PM   #3 (permalink)
well thanx i use panda antivirus and also thenx for the site found them usful
