Old 17-07-2005, 07:54 PM   #1 (permalink)
Default TweakNow RegCleaner Standard - Results not clear
On running TweakNow RegCleaner Standard it reported the following :
1) HKCR\CLSID\(.... some numbers....)\ImprocServer32 ADMPROX.dll
2) ..................... do ....................... deskpan.dll
3) ..................... do ....................... ADMPROX.dll
4) ..................... do ....................... ADMPROX.dll
5) ..................... do ....................... ADMPROX.dll
6) ..................... do ....................... ADMPROX.dll
Under Problem details :
UNKNOWN
The program unable to determine status of ADMPROX.dll & deskpan.dll
I wonder as to which program these entries belong and whether it will be safe to delete these 6 entries from the registry ? Are these orphan entries left behind ?
Am using WinXP Pro.
Regards
Narinan
Nariman is offline
Old 18-07-2005, 11:58 AM   #2 (permalink)
swatkat's Avatar
Those files come with Windows XP SP1. They are some system files. Most probably those entires are broken links to those files. If you have the provision to take backup using TweakNow, then you can remove those entries.
http://swatrant.blogspot.com/
swatkat is offline
Old 18-07-2005, 03:30 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
if in doubt use/cross check results with
ccleaner or ace utilities. they are absolutely safe.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 19-07-2005, 12:14 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
b careful while using these softwares ...
might take u in serious trouble ...
... W H O T ...
ax3 is offline
