if u r in winXP SP2 u might try this
Give this a shot... Start > Run > Type "cmd" without the quotes and press enter > in the command prompt window type "del C:\hiberfil.sys" without the quotes and press enter.
Next press Start > Click Turn off Computer > Press the SHIFT key and the hibernation mode should appear > hibernate and then turn the power back on to see if that works.
rebooting
ChotoCheeta.com
