Old 17-07-2005, 05:18 PM   #1 (permalink)
Default Should i go in for the athlon64 2800+ compared to the 3000+?
Coz there is a Rs2000+difference for only an additional 200Mhz !!!!!!!!!!
Plz help me !!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 18-07-2005, 12:17 AM   #2 (permalink)
If you're talking about Socket 754 CPUs, it depends on your needs and expectations. For most applications, you'll hardly ever notice the difference between 2800+ and 3000+. Personally, I'd spend the 2k for something else such as a better gfx card, more RAM, speakers, etc. These things will produce a much more noticeable difference in performance. However, if your budget allows you to buy all these other things AND a 3000+, then go for it.
OTOH, 3000+ is the lowest processor available in socket 939. The advantage of S939 is that motherboards with more future-oriented features are available for them, such as PCI-E slots.
I use the term "future-oriented" instead of "future-proof" because nothing is really future-proof in computers except for a short period of time.
pimpom is offline
Old 18-07-2005, 12:25 AM   #3 (permalink)
siriusb's Avatar
I would strictly advise you to look into the aforementioned processor's reviews (here's one from xibitlabs.com) and to decide for yourselves if the perf diff u see are justifiable, relevant to the type of app u will be running.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 20-07-2005, 11:19 PM   #4 (permalink)
thanx I see that the Athlon 64 2800+ is not much different from the Athlon 64 3000+ apart from the 200mhz More of the of the 3000+ !!! I see the 2800+ better compared to the 2k+ more 3000+ !!!
Now i prefer the Athlon 64 2800+ over the 3000+ !!!
thanx 1ce again !!!
Cheers !!!
