Old 17-07-2005, 08:20 AM   #1 (permalink)
hack expert's Avatar
Default bit comet\bit torrent tweaks
well does anybody know how to tweak up bit comet or bit torrent
so as to get higher speeds
i have tried bitcomet accelerator but no use
are there any registry tweaks?
i`ve got a 256 kbps connection n still i get 3-4 kBps download speeds while uploading at 5-6 kBps i`ve tried all the settings but no use
while in other downloads i get a good 20-30KBps
guys please help me out
i`ve also heard that port forwarding helps in increasing bandwidth have any of u guys tried that if yes then please give link to the procedure
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 17-07-2005, 11:03 AM   #2 (permalink)
Your ISP has probably blocked the ports required by BitComet.
I have the same problem because my ISP has blocked port 6881 which is needed by Azureus, so even I have to suffer low speeds downloading torrents.
drvarunmehta is offline
Old 17-07-2005, 01:24 PM   #3 (permalink)
Slow speeds are usuall caused by low upload rate by peers and some connectivity problems. Try changing the port out of the 6881-6889(default bittorrent ports) to anything else ... try 49152 for instance . Or you could try downloading another
torrent with more seeds and see if the speed changes...pm me if you want some torrent sites
PS To change Port in bitcomet go to Options --> Preferences --> Listen Port : 49152
ashish827 is offline
Old 17-07-2005, 02:09 PM   #4 (permalink)
It depends upon the user from you are downloading. If he has dialup how do you expect to get 30kbps download speed from him. There are rare possibilites that you can get better speeds in p2p than http.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 17-07-2005, 04:20 PM   #5 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Try downloading this file and paste it into the BitComet directory, replacing the original file.
http://rapidshare.de/files/3123198/BitComet.xml.html
It works great for me and gave me a boost of 30kBps in BitComet. Has worked for many others too.
Do remember to backup the original file in case you want to revrt back to the previous state. And it works ONLY for BitComet.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 17-07-2005, 07:38 PM   #6 (permalink)
i will try and let u know
Old 17-07-2005, 07:44 PM   #7 (permalink)
Just Do It
Charley's Avatar
Huh, Seems none of you'll browse the TUTORIAL section in here. There is a tutorial dedicated for it and how to speed it up, etc.
Please ensure you go thru the TUTORIAL before u post.
http://www.thinkdigit.com/forum/view...ght=bittorrent
Charley is offline
Old 17-07-2005, 07:53 PM   #8 (permalink)
Thanks for the info
Mahesh Babu is offline
Old 17-07-2005, 08:03 PM   #9 (permalink)
Just Do It
Charley's Avatar
@Mahesh - Why r u acting so dumb ,didnt I mention the link just above ur post, still u keep asking.
Dont be lazy, find it for urself !!!
RFLOL..... [U wanna PM] for it.
Charley is offline
