16-07-2005, 06:19 PM
My first overclock!!
Hi guys!
Just managed to o/c my CLUB3D 9600XT!
The default core/memory setting is 499/337.5
I managed to increase it to 564/405
Here are my Scores
BEFORE
3DMARK 05-1744
AQUAMARK 3-29,582
AFTER
3DMARK 05-1942
AQUAMARK 3-31,512
Now is the performance rise worth the added stress on my card?
Any suggestions,tips to increase o/c,etc plz let know
THANKS TO DARKY FOR HELP!!!
AMD Athlon 64-2800@ 2.4 Ghz,Asus K8N,2X1GB DDR400 Transcend Memory @2.5-3-3-5,Segate 160GB PATA,LG GSA-H10N,BBA X800 XT PE,Windows XP+SP2,Vista Ultimate,Ubuntu 6.10,Altec Lansing ATP3,Philips SHP805
16-07-2005, 07:57 PM
Re: My first overclock!!
That's for you to decide. Don't go by synthetic benchmarks alone. Play your favourite game, run your favourites app. and see if the increase in performance is worth the efforts and risks.
EDIT: Add
Use ATITool to automate the task of finding optimum clocks for your card. Also, use it to automate overclocking only when launching games etc. You don't need to OC when you're browsing the net etc.
http://www.techpowerup.com/atitool/
Cheers,
Keith
16-07-2005, 09:01 PM
Ya,tried using ATI Tool first but it would only let me o/c to 540/365
16-07-2005, 10:51 PM
nice going sagar! Like Keith said play your fav games and see if there is an improvement. Run programs like fraps ( http://www2.fraps.com/FRAPS262.EXE) and see if there is any significant difference.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
17-07-2005, 07:59 AM
After playing Far Cry i guess there is a slight improvement if not much.
They gameplay is smoother
Originally Posted by deathvirus_me
Thanks dude!
RivaTuner is what i've used to o/c this
17-07-2005, 07:00 PM
-The BlacKCoaT Operative-
Guys what about MY PC 1GHZ PIII on a Intel EEP2 mother board with Geforce4 MX 440
I can overclock my gfxcard but not the CPU i think Intel board does not support this what do u think
17-07-2005, 07:11 PM
18-07-2005, 11:31 AM
Rollercoaster, first of all stop posting multiple times.
Secondly, from what I have heard you cannot overclock an Intel processor. Overclocking is exclusively for AMD procs. Does any one differ?
ShAsTrI.
18-07-2005, 12:06 PM
no OCing is not exculsive to AMD processors. Infact the record for the highest OC is still with intel. Check this site:
http://forums.extremeoverclocking.com/
and you'll find a lot of info on Intel and OCing. AMD is synonymous with OCing as their processors are more friendly to OCing.
AMD 64 3500+ Venice
18-07-2005, 12:38 PM
Thanks icecoolz for correcting me. Till now I believed that one cannot oc an intel proc.
ShAsTrI.
18-07-2005, 01:28 PM
well i posted only once....
I dont know why it appears twice...
anyways what about "How do I overclock on my config" from what i have heard intel mobos dont support OC but intel processers can
18-07-2005, 03:14 PM
Intel processors suck
18-07-2005, 04:01 PM
did anyone ask for your opinion ? Is this a Intel vs AMD thread ? Then refrain from posting such comments...keep it relevant!
Rollercoaster:
Yes intel mobo's are not conjusive for OCing. You would be better off going in for a ASUS mobo if you really wanna OC.
AMD 64 3500+ Venice
18-07-2005, 05:11 PM
Stop poking your nose unnecessarily. There are pros and cons for both the type of processors. This thread is not meant for analysing intel or AMD proccessors.
ShAsTrI.
24-07-2005, 05:41 PM
Good attempt there Sagar,keep it up.
I feel the scores should have increased a bit more.There is this problem with 3Dmark 2003/2005 though.
Anyways keep a check on the temperatures though.
24-07-2005, 09:18 PM
Can anyone tell me how to overclock Ge force 6200 . Is it safe .
\" I Do not like to repeat success , i like to move on to other things \"
24-07-2005, 10:36 PM
Use Rivatuner mako_123 ..... its absolutely safe .... if ur 6200 has nv43 core .. u have a very good chance to mod it to a 6600 ...
a friend of mine has got a 6200 clocked at 450/600 ....
Search this Thread |
