Old 15-07-2005, 11:59 PM   #1 (permalink)
Default Which CD writer to buy SONY or ASUS?
Hi !
I already have a DVD ROM[Sony].Now I am planning to buy a CD writer,but I am confused which one to buy; Sony or Asus? Please advise..
regards
Gopal
balagopalks is offline
Old 16-07-2005, 05:22 PM   #2 (permalink)
i suggest Sony
Shwetanshu Srivastava
shwetanshu is offline
Old 16-07-2005, 06:17 PM   #3 (permalink)
tuxfan's Avatar
Sony
tuxfan is offline
Old 16-07-2005, 07:49 PM   #4 (permalink)
seriously speaking go for SONY and dont even think of ASUS.
coz i have heard that ASUS has higher problems reported than SONY.
Also if u have any problem with SONY u can directly go to their nearest service centre but ASUS doesnt have such facility i.e if problem occurs u have to go to the dealer,then he will contact service centre ans so on.
harshagarwal is offline
Old 16-07-2005, 07:55 PM   #5 (permalink)
I have had a very bad experience with ASUS cd writers. Opt for Sony or LiteOn.
paraman is offline
Old 17-07-2005, 02:41 PM   #6 (permalink)
busyanuj's Avatar
go for a Sony or Lite-On rewriter.
busyanuj is offline
Old 19-07-2005, 09:45 PM   #7 (permalink)
Default LITE-ON
it will be better if u go after LITE-ON rewriter.this is better than sony and asus.
i have a great list of friends complaining abt both sony and asus.
some of my friends have tray problem in sony and computer halts number of times in case of asus.
asus is better than sony
check out for the availability of service centres.
masterasmit is offline
Old 19-07-2005, 11:26 PM   #8 (permalink)
sidewinder's Avatar
Dont even think of Sony.It has a very weak lens.Asus is good performancewise but if it starts giving problem then it wont stop.Lite on is the best choice.Only con it has is it has only 1.5 mb buffer memory.But still its the current performance champion.
Bombina rocks
sidewinder is offline
Old 19-07-2005, 11:46 PM   #9 (permalink)
The Hardware Labs
mohit's Avatar
Asus performs better and I have not seen or heard my fnrds have problems with it. Sony had given some probs to some of them. I prefer Asus.
mohit is offline
Old 20-07-2005, 02:36 PM   #10 (permalink)
Just Do It
Charley's Avatar
This should be of great help.
http://www.thinkdigit.com/forum/view...t=cdwriter+buy
Charley is offline
Old 20-07-2005, 02:52 PM   #11 (permalink)
go for liteon. it is best
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
Old 20-07-2005, 08:09 PM   #12 (permalink)
Just Do It
Charley's Avatar
Threads already exists. Search for them.
Anyway recommend u to go for sony or liteon only.
Charley is offline
Old 21-07-2005, 01:15 PM   #13 (permalink)
Netjunkie's Avatar
My friend has been using ASUS cd writer for more that a year now. He has not faced even a single problem till now.
I suggest ASUS.
Netjunkie is offline
Old 21-07-2005, 01:26 PM   #14 (permalink)
Just Do It
Charley's Avatar
I suggest ASUS.
not all have the same impression as u.
go for the brand that is in demand and has a reliable service.
Charley is offline
Old 22-07-2005, 09:07 PM   #15 (permalink)
hack expert's Avatar
well after such a discussion it is obviously sony
well i personally have used sony it`s got excellent performance and service
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 23-07-2005, 02:15 PM   #16 (permalink)
dOm1naTOr's Avatar
Sony is the worst in perfomance. My Sony DVD ROM is slower than a turtle. My friends have the same pboblem.
Asus drives are prone to problems but blazing perfomance.
I recomant go for LiteOn or Benq(2 YR warranty).
My Benq CDRW is a good performer as well as good quality.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-07-2005, 03:04 PM   #17 (permalink)
Just Do It
Charley's Avatar
I've been using this since many months and no probs, performance wise it is really good.
Fair enough u cud for Liteon also which I'd say is the best in the mkt tday.
Charley is offline
Old 11-08-2005, 06:01 PM   #18 (permalink)
Thankz all for your replies!
regards
Gopal
Old 11-08-2005, 06:19 PM   #19 (permalink)
Do a search on this. Asus should be BENQ, Sony is the same as the liteon but more reliable. Liteon will usually be the fstest drive but the worst in writting DVD's compared to any but the old samsung. Pioneer, NEC, BENQ, LG would be the choices.
AlienTech is offline
Old 11-08-2005, 07:19 PM   #20 (permalink)
Never go for Samsung or Sony optical drives.
Look for LG/Pioneer brands.
Mahesh Babu is offline
Old 11-08-2005, 08:14 PM   #21 (permalink)
Commander in Chief
QwertyManiac's Avatar
Samsung Drives are very good in readin scratched disks,
Sony rocks in Drives
Lite-on is a good choice
ASUS is a better choice
LG , i havent tried
ACER is a short buy (works bout 2 months)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-08-2005, 08:28 PM   #22 (permalink)
sony is better than asus,, the only problem in sony is that it reads slowly at the initial stage. after that its all ok. and that is especially in a dvd writer. in cd writer sony is much much better than asus.. asus cd rom is good but in case of cd writer asus is not at all nice.. on later stage asus stops detecting black cds. u have click on refresha nd detect again to check.. then at last it will work.... there has been vote for both asus and sony. but believe me.. i used samsung in 1999,, then changed to LG, LG was nice but now it is not... asus is average(cd rom is grt not cd writer) and then i went for sony, our group is 28 people use sony cd writer and it is the best. IF IT IS A CD WRITER THEN BLINDLY SAY SONY -- THAT OVER AND OUT
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
