Is there anyway i can change my shared VGA memory from 32mb to 64mb in BIOS?
Heres my PC config:
P4 1.7GHz
512Mb DDR RAM
A VIA U8668R16 Motherboard
S3 Pro Savage DDR Onboard Graphics Controller
Windows XP SP1
Award Modular BIOS v6.00PG
go to BIOS.. and change it.. ul have an option i think in advance chipset features.. been a long time since i used a comp with award bios.. ul find onboard AGP memory or somehin
Go to the BIOS, there search for the option like "Shared VGA" or "Shared Graphics" and check the options. If you have 64 MB in the options, choose it.
If there is no 64 MB option in the BIOS, then you can do nothing.
