Old 15-07-2005, 12:52 PM   #1 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default how should i deal with this folder??
I recently found out that there is a folder on my hard disk which i created almost 2 months back and is having mp3 songs in it , but now when I try to open it , or right click on it , system gets hanged.
i cannot open it and also cannot delete it. when i try to delete it , it says access denied.
can anyone help???
~Phenom~ is offline
Old 15-07-2005, 01:12 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
as usual....
1. what OS u r in...??
2. Check ur system with a good AVS & good antispyware....
3. to delete Open the mother directory with command prom... use RD The folder name command..
type help in command window to know more... in how delet the directory..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-07-2005, 01:18 PM   #3 (permalink)
which os u r using
if it's xp just run attrib <folder name> -r -s in cmd
and unshare it ,
then
all u got is either 0 or 1 there is no place for 1/2 same is also true for life.
vegeta_killer is offline
Old 15-07-2005, 01:22 PM   #4 (permalink)
which os u r using
and unshare it ,
then
Old 15-07-2005, 01:49 PM   #5 (permalink)
rajat22's Avatar
Install 'Steganos Internet Trace Destructor 7' or 'tuneup utility 2004'.
Rt click on these folder and select 'destroy' or 'tuneup shreder'. Erase it for ever.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 15-07-2005, 03:18 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
download and use "delete doctor" to remove it.
http://www.diskcleaners.com/
to find out who has locked it use "WhoLockMe"
http://www.pcworld.com/downloads/fil...d,25368,00.asp
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 15-07-2005, 08:01 PM   #7 (permalink)
swatkat's Avatar
If you are using Windows XP, try this. Acquire the ownership of that Folder by doing this:-
1] Right-click the folder that you want to take ownership of, and then click Properties.
2] Click the Security tab, and then click OK on the Security message (if one appears).
3] Click Advanced, and then click the Owner tab.
4] In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of that folder, select the Replace owner on subcontainers and objects check box.
5] Click OK, and then click Yes when you receive the following message:
You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?
All permissions will be replaced if you press Yes.
Note folder name is the name of the folder that you want to take ownership of.
6] Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
After acquiring the ownership, try to Open\Rename\Delete the folder.
More Info
http://swatrant.blogspot.com/
swatkat is offline
Old 15-07-2005, 11:17 PM   #8 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
thanx guys for ur suggestions
the problem is solved
mods , u may lock it!
~Phenom~ is offline
Old 15-07-2005, 11:34 PM   #9 (permalink)
Topic Locked -digen
www.Oobertech.net
digen is offline
