Old 14-07-2005, 09:08 PM   #1 (permalink)
Default Autopatcher infected with trojans???
I installed .NET framework from Autopatcher May 2005 edition. avast! detects a trojan in one of the installed files. Is this a false positive or other antivirus programs are detecting it too?
drvarunmehta is offline
Old 14-07-2005, 11:40 PM   #2 (permalink)
swatkat's Avatar
Most probably it's a false positive (heuristic warning?). You can upload and scan the file here.
http://swatrant.blogspot.com/
swatkat is offline
Old 15-07-2005, 01:41 PM   #3 (permalink)
guys there are lots of problem with autopatchers
My windows media player10 stopped working creating a menace , it's not recovered from errors yet
it dont starts nor uninstalls
and all softwares that run using WMP10 have stopped working
who the hack is this??
mukul is offline
Old 15-07-2005, 02:06 PM   #4 (permalink)
sunnydiv
Posts: n/a
mukul
as dexter once told me, i tell u.
"WELCOME TO THE CLUB"
Old 15-07-2005, 03:21 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
u r right. had noticed the same thing. the spyware dotnet is present in autopatcher may. just 'uncheck' its installation or remove it with ur anti-spy afterwards.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 16-07-2005, 07:03 AM   #6 (permalink)
rajat22's Avatar
Absolutely similar problem with me . Used autopatcher after a format on XP SP 2, yet to be solved.
Any how let us all investigate into this matter.
Though
AutoPatcher XP July 2005 Full/Lite Released
Size of Full - 153 MB
http://cpugeniusmv.org/hosting/apxp/...l2005_Full.exe
Size of Lite - 73 MB
http://cpugeniusmv.org/hosting/apxp/...l2005_Lite.exe
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 16-07-2005, 10:15 PM   #7 (permalink)
anandk's Avatar
rajat22, liked ur style had a good laff after quite a long ime ! look forward to seeing more of ur such multiple posts !!
Microsoft® MVP
anandk is offline
Old 16-07-2005, 10:24 PM   #8 (permalink)
rajat22's Avatar
@ anandk
Believe me , the forum site was not behaving properly
Sorry again
rajat22 is offline
Old 18-07-2005, 09:03 PM   #9 (permalink)
mariner's Avatar
and all this time i was wondering what happened to my WMP 10 !!!!!!!!!!!!!!
mariner is offline
Old 19-07-2005, 07:49 AM   #10 (permalink)
rajat22's Avatar
'theraven' at QA section taught 'reinstalling windows without losing data'.
WMP 10 problem, can reinstallation cure it???
But ,this time after reinstallation, I am not going to use autopatcher any more
rajat22 is offline
Old 19-07-2005, 11:56 AM   #11 (permalink)
Default Re: Autopatcher infected with trojans???
There were no problems with me when i installed autopatcher, even i use avast antivirus, scan it again and see if you get the same message again.
loo_31 is offline
Old 19-07-2005, 02:18 PM   #12 (permalink)
Thor's Avatar
Hmm! Mine also went Smoothly. And I also use Avast 4.6 HE with Latest Updates. Urs may be a unlucky case ?
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 19-07-2005, 05:04 PM   #13 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Trojan HUH ?????
HEY dont u guys ever read readme files in yr lives ?????
AUTOPATCHER CLEARLY MENTIONS THAT ANTIVIRUS CREATES SOME ALERTS AND THUS RECOMMENDS U TA OFF IT AS IT WORKS WITH WINDOW"S UPDATES THRO REGISTRY EDITING
Hope u understand (non update downloaders)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-07-2005, 10:18 PM   #14 (permalink)
Thor's Avatar
Be Polite. U sound exasperated. Ur behaviour is highly Condenscending.
Thor is offline
Old 20-07-2005, 07:54 AM   #15 (permalink)
rajat22's Avatar
@ QwertyManiac
Please ask your autopatcher to make our WMP 10 ok.
We have read the readme files dude.
A similar problem to many after autopatcher, demands an enquiry, right??? :roll:
We are not fighting here 8)
rajat22 is offline
