Old 14-09-2004, 01:43 PM   #1 (permalink)
Default auto shut down
hi frnds
i have a celeron 1.7 ghz with 256 mb ram 80 gb hdd & win XP SP1 . i bought this in june but i have a srious problems from that time my pc automaticly shutdowns no warning nothing its just turns off when i try to restart it doesnt strats . i have to switch off the main power supply an start all over again . i have good power suppy ther is grnd in the power supply . i even got one ups but still no solution my dealer said maybe there is virus . so he formatted the hdd but after some days same thing is happening. one peculariti my pc shutsdown after approx one hr after i have have switched it on . it happens every hr
need help on that any one i gone mad abt this
agm_105 is offline
Old 14-09-2004, 07:01 PM   #2 (permalink)
Medic on Call!!
medpal's Avatar
does it give 1 min countdown before shutting down?
i think there may be blaster worm on your comp.
post your hijackthis log file here for the pros to help you.
medpal is offline
Old 14-09-2004, 07:27 PM   #3 (permalink)
aadipa's Avatar
u may be having faulty power supply
also check if ur motherboard/processor doesn't over-heat
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 14-09-2004, 08:00 PM   #4 (permalink)
@medpal ... i dun think the worm would give a 1 hour waiting before giving hte one minute warning
and im quite sure he didnt get a warning ... so my bet is a faulty PSU too ... and since he shuts down and immediately restarts .. i doubt it being heating problems either ...
but yet .. give all three a try .. theres always something new
No Mercy, No Limits.
theraven is offline
Old 14-09-2004, 08:01 PM   #5 (permalink)
there is no coutdown i have cheked with mcaffe virus it doesnt show any virus. i have updated WIN XP . thnx for concern
any other solution let me know
agm_105 is offline
Old 14-09-2004, 08:09 PM   #6 (permalink)
how to check power supply ? also when first time this problem occured i asked my dealer to change m/b and processor
i had mercury m/b now i have a krypton m/b both where 845 chipset any other sepcification u want plz let me now
thnakx for ur concern
agm_105 is offline
Old 14-09-2004, 10:39 PM   #7 (permalink)
well if it doesnt work with the new mobo and proccy then its definitely the power supply
either ways .. try using a friends power supply ... or get a spare from somehere and use it .. and check whether the system still shuts down in an hour ...
theraven is offline
Old 16-09-2004, 07:26 PM   #8 (permalink)
mebe da cabinet is spoilt somehow....or da part in da cpu wich handles elec....once this happened 2 me cuz a SCREW fell inside my motherboard n something happened n it melted sumhow
ishaan is offline
Old 20-09-2004, 03:32 PM   #9 (permalink)
agm_105
you may do following things -
Dont boot your pc up to XP. Instead go to CMOS settings and keep their ideal for few minutes. Best if you keep in CPU/Fan temp and rpm page. It also help you to observe the status of your pc. If here is your pc give a reset then most probably you have a faulty MBD.
Check the voltages if you have any multimeter. And also Ground. UPS take care your voltage fluctuation but not ground. It should be below 4V (Neutral-Earth voltage).
Check the Eventlog in XP and try to find probable cause for shutdown /reboot.
I have a problem a few days back. My XP got rebooting while booting and i have to wait for half an hour before making power switch on. It was the earthing problem. I have corrected and now pc working well
Think of me n I will be there
amistik is offline
