Old 14-07-2005, 02:42 PM   #1 (permalink)
eagle_y2j's Avatar
Default Plzzzzzzzzzzzzz help me out of it!!!!!!!!!!!
I am having a system with win xp on a 40 gb hdd having 4 partitions i.e. c,d,e,f all things were going fine but few days before on starting my computer i got some message that one of the file of os is corrupt & i need to reinstall it so i installed a fresh copy of win xp pro on c drive and i am facing a problem that i was having password protected account before and my document folder containing my imp office files were on d: drive but after istalling a fresh copy of win xp i am not able to acess my my document folder when i try to open it says acess denied plzzzz help
.The files inside r very important to me........................................
Registered LINUX USER #438929
eagle_y2j is offline
Old 14-07-2005, 05:28 PM   #2 (permalink)
hack expert's Avatar
all u have to do is repair the older version of win xp installaition
or have u overwritten the old installation
well if u have overwritten the docu n setting folders is not changed and hence the folders are still private
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 14-07-2005, 05:30 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
humm..
I think win98SE would b a good idia... get a win98SE cd... or a boot up floppy disk made from Win98SE system... boot from them... run ur system command promt.... i think it should allow u 2 access that folder...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 14-07-2005, 08:14 PM   #4 (permalink)
eagle_y2j's Avatar
@ saurav_cheeta frnd i forget to specify my all of drives r formated with NTFS file system so...................!!!!!!!!!!!
Old 14-07-2005, 10:01 PM   #5 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: Plzzzzzzzzzzzzz help me out of it!!!!!!!!!!!
hmm..
shouldn't be much of a problem...
Go to --> My Computer --> RightClick on D drive -->Properties-->Go to "Security" Tab-->Click on "Advanced"--->Goto "Owner" tab--->Select ur name there and also tick mark "Replace owner on..."-->Apply...
DONE.....
Hope this helps...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 15-07-2005, 10:37 AM   #6 (permalink)
eagle_y2j's Avatar
@ JAK My frnd it really helped thanks................... for ur help
