Old 14-07-2005, 12:19 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default without welcome screen in xp
hello My configuration is as follows:-
· Amd anthlon 3000+
· MSI K8MM-V
· 256 MB RAM hinux(shared)
· 80 GB SATA segrate
· sony combo drive
· no graphics card is installed
Operating system is windows xp
I have 4 partitions 2 of 6.81 GB. And 2 of 30.4 GB. Once I had two oses. Windows 2000, Windows xp.So I formatted windows xp And using windows 2000 I upgraded 2 win xp using cd of xp. My newly upgraded xp is opening my account i.e password protected. Without using welcome screen .also need sp1 &sp2 in a cd or some other way b'cos no internet is avaible but can download some files below 2.5 mb
Can anyone one help!!!!!!!!!!
gary4gar is offline
Old 14-07-2005, 02:40 PM   #2 (permalink)
in the control panel section user accounts change the way users log on or off use welcome screen. that shud do it
ankit_biz is offline
Old 15-07-2005, 02:31 PM   #3 (permalink)
open run menu and type
CONTROL USERPASSWORDS2
and select option login with out attempt of password
that's it
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 21-07-2005, 04:20 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
hey gettin sp2 is simple
visit microsoft.com and in the download section theres a link called 'order cd'
DONT WORRY its 100% FREE and is delivered within 4 weeks
if u cant wait jus send me a mail with ur address and ill courier it ta ya (i got 3 cds)
also u dont need sp1 if you install sp2 alone (its combined)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-07-2005, 05:38 PM   #5 (permalink)
alib_i's Avatar
i think you've got your solution, so I wont explain it to you again.
Just that SP2, as qwerty above said, can be ordered for free from M$
This is the link: Order Windows XP Service Pack 2
alibi
-Metallica
alib_i is offline
