i have the main purpose of the rig is for 3d modelling with software like maya 3d studo max.
AMD
- Office PC/Basic home PC
- Hardcore Gaming
- CAD and Development workstation
Pentium
- Heavy Audio/Video encoding
- Photoshop, 3D rendering
So hope this helps.
If you want for Maya , 3D Max , Photoshop Intel will be a better choice than AMD.
But if you want for Gamming then AMD without any second thought.
AMD 3500+ Venice - approx 15K
Corsair would be gr8 but , Hynix D43 Orignal are also gr8.
PC 3200 DDR400 2x512MB Rs 4750-5250 approx
Motherboard
Are you going for 2 GPU's seriously then only get a NF4 SLi Motherboard.
Else get a NF4 Ultra Motherboard.
Also ASUS is a better choice because it has gr8 service in India.
There is no MSI A8N Sli its MSI Neo 4 Platinum/SLi or K8N Diamond
My Reco's
For SLI - ASUS A8N Sli [NForce 4 SLi Chipset - Socket 939]
For Non SLi - ASUS A8N-E [NForce 4 Ultra Chipset - Socket 939]
ASUS Ultra Chipset comes with single PCI-E x 16 Slot also not firewire support.
Cost :- SLi approx 11-12K , Ultra - 8800Rs
From Rashi & Prime ABGB Mumbai.
Also remember the 7800GTX will be very costly but is a fantastic GPU.
Instead you can have 2x6600GT in Sli
