Old 13-07-2005, 05:18 PM   #1 (permalink)
plsoft's Avatar
Default Divx Movies No sound!!!!!
i have Divx Movies but the problem is that there is no audio when i play them with RealPlayer10, Windows Player10 n PowerDVD. However ther is no prob with the video.
I can play both the video n audio with VLC player only.
Is there anything wrong with my confi?
P4 2 Ghz 512Mb RAM
Win Xp SP1
plsoft is offline
Old 13-07-2005, 05:29 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
u forgot to mebtion the main thing... SoundCard or the mobo type...
tell us little more about ur Problem....
1. Did u installed the Sound Drivers??
2. Can u play DVD or VCD movie wothout problem....??
3. SP2 is free can b access easly... so try to install the SP2...
get back with th result...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-07-2005, 05:49 PM   #3 (permalink)
plsoft's Avatar
well my mobo is ASUS PV533-MX n i have Creative soundblaster live 24 bit external sound card.(The drivers are installed).My speaker is Creative Inspire 6.1 6600. I can play DVD n other formats smoothly
plsoft is offline
Old 13-07-2005, 06:53 PM   #4 (permalink)
Another Brick in the Wall
drgrudge's Avatar
LOL.. the player might have been encoded with AC3 audio codec and you will not have that installed.
You can check wht codec you have or dont have have here:
Gspot:
http://www.headbands.com/gspot/gspot252dl.html
Or downlaod this :
K-Lite Mega Codec Pack 1.34
http://www.softpedia.com/progDownloa...oad-15909.html
Install that and you can play all files without audio/video problems.
It got nothing to do with hardware.
drgrudge is offline
Old 14-07-2005, 12:40 AM   #5 (permalink)
hafees's Avatar
Yes. Your divx movie may be encoded using ac3 audio or an audio encoder that is not supported by other players because in your system that codec might not be installed.
If you have virtual dub then u can check how the audio is encoded. Open that movie in virtual dub and click the menu File -> File information. It should show video information and audio information. In audio it will show how many channels is available,
which format etc ( it may show unknown if it is not a supported format ). if the channels show 6 then it is encoded in ac3. You may download a free ac3 decoder from the link below.
http://ac3filter.sourceforge.net/
hope this works
hafees is offline
Old 17-07-2005, 09:28 PM   #6 (permalink)
plsoft's Avatar
thank guys, it works now after i installed k-lite codec pack
plsoft is offline
Old 17-07-2005, 11:24 PM   #7 (permalink)
bharat_r's Avatar
I have a 20 min video clip(DVD-Rip I think) encoded in DivX.When I try to convert it to VCD the audio is lagging behind video.
Why is it?
bharat_r is offline
Old 18-07-2005, 01:33 PM   #8 (permalink)
alib_i's Avatar
audio lag is the most common problem with encoding videos.
your divx file must be having some errors and b'coz of that you get a skewed file.
i dont have a practicle solution to this .. so .. dont ask me wht to do about it
alibi
-Metallica
alib_i is offline
