Old 13-07-2005, 03:59 PM   #1 (permalink)
Default vedios dont work ....
hi,
two vedio files from digit cd of this month dont seem to work .... they are the "harry potter 4" and "batman begins" ... i think sone codec is missing ... i have media player 9 and quick time ... plz tell me what i can do ...
Saurya
Physics-Philosophy-Saurya
saurya_mishra is offline
Old 13-07-2005, 04:20 PM   #2 (permalink)
expertno.1's Avatar
1)post in the Q+A section ..so told to mods
2)use Ace mega codec
3) use Jet audio plus
4) use isobuster if the file is not being copied
and done
expertno.1 is offline
Old 13-07-2005, 04:51 PM   #3 (permalink)
upgrade to the latest version of Win Media Player ie version 10
i think you should also install the VLC player that was available in one of the recent DVD's ( im sure it was in may 2005 > essentials)
good software...has codecs for most of the video formats
A flea and a fly in a flue, were caught, so what could they do? Said the fly, \"let us flee!\" \"Let us fly!\" said the flea. So they flew through a flaw in the flue.
technovice is offline
Old 13-07-2005, 09:57 PM   #4 (permalink)
q3_abhi's Avatar
Install a K-lite Codec pack and u r done!!!!!
Or VLC is also a good option to go for.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 14-07-2005, 02:39 PM   #5 (permalink)
Just Do It
Charley's Avatar
those worked on klite codecs ..
Charley is offline
Old 14-07-2005, 05:41 PM   #6 (permalink)
Tux Fan
shaunak's Avatar
me was thinking divx
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 15-07-2005, 01:47 PM   #7 (permalink)
VLC !!!!!!!!!
works fine with them
who the hack is this??
mukul is offline
Old 15-07-2005, 08:55 PM   #8 (permalink)
Just Do It
Charley's Avatar
Originally Posted by mukul
VLC !!!!!!!!!
Really, the wmv, avi files which I had dont run smoothly which is perfect as in Klite, WMP?
Charley is offline
Old 24-07-2005, 08:35 AM   #9 (permalink)
Ok, which one should i install? The basic klite or the full one ?
Old 24-07-2005, 01:33 PM   #10 (permalink)
Another Brick in the Wall
drgrudge's Avatar
saurya_mishra:
See you dont have to install neither, you can run GSpot, and see wht codec you dont have and google for it and then install them.
But in case you are lazy, you can install Klite basic one itself, it wont have some extra features like BSplayer , quicktime/real alternative like that, but it will have all the codec that it necessary to play the videos.
drgrudge is offline
Old 24-07-2005, 04:36 PM   #11 (permalink)
thanks every body. the problem is solved. I updated my media player and installed the new codecs for quick time player.
Saurya
