Originally Posted by Sreekanth V
Object dock can't replace taskbar but it seems to be a good addon.
Are you using the free version? Then try the Plus version. It has the ability of hiding the Windows taskbar.
I am using the Plus version. Yesterday I have updated my OD+. Downloading the '
ObjectDockPlus--120.exe' file from 'Stardock store' double-click on it and the installation is very simple - just invoke the product key you have received from Stardock through mail.
It's really a nice as well as very much useful to me. I am using a AMD64 based PC with 512 MB (400 MHz) RAM and 120 GB SATA HDD. So, it's enough fast to use OD+ as a start-up item.
