Hmm that means you have to enter the values (260). This value is called as Offest value where the hex code resides. The hex code that is present at that location should be changed with FF.
..:: peace ::..
Jeba
STILL HAVE'NT UNDERSTOOD
DETAILED explaination needed .......
Btw, if any of u can edit the file with the requirements for me ... i would be very grateful!
Replace hex values at offset 260h,261h,262h with FF,FF,FF
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
