Originally Posted by crashuniverse
i can suggest one thing but i m not sure its gonna work or not.
find something on bios to disable SILENT BOOT. disabling it does memory test at the beginning. And thats exactly where u see the results.
U need to be quick there as it flasghes only for 2 s n then it goes on...
well thats what happens with my intel but u say u have amd so there can be a variation on the bios.
Dude, that's what godblesssedson said too. And disabling silent boot don't do mem testing, it just shows the bios post screen, which is all that is needed.
But the elegant way, as suggested by others, is to use cpuz.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
