Old 11-07-2005, 02:55 AM   #1 (permalink)
Default Intex Mic
hi friends,
I just bought an Intex Speaker Microphone. The trouble is while the speaker works fine, the mic picks up everything..converts into a noise..and then whilei can speak..the other person listens nothing.
I tried to play around with the settings but with limited sucess.
I have an Aureal SoundCard(thats external) and also an onboard sound card(which i dont use)
can u guys help
plz
kooladi is offline
Old 12-07-2005, 07:25 AM   #2 (permalink)
q3_abhi's Avatar
Try using it on other system. If the problem persits then try another mic n see if the problem is solved.
If the mic doesnt work on other system then exchange it from where u took it.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 12-07-2005, 07:52 PM   #3 (permalink)
siriusb's Avatar
I had a similar issue where a lot of noise is heard than voice. Mine was solved by turning off the "1 mic Boost" in advanced control for microphones dialog.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 12-07-2005, 08:49 PM   #4 (permalink)
expertno.1's Avatar
it can be "1 mic boost" or "2 mic boost" try to use both and see as in my case its mic 2 boost
also lower down the valuse of input of mic
also try it on other system
also contact the vednor if it doesn't solves the problem
expertno.1 is offline
