how to connect svideo o/p of my pc to normal i/p of my tv
hi guyz
can i connect the s video o/p of my pc to the normal i/p of my tv. coz my tv doesn't have a svideo i/p. also can i connect my audio o/p to my sony 5.1 9000W home theatre.
help reqd guyz
hi guyz look at the spidey
You'd get better replies if you posted your graphics card make and model. And types of output supported by your sound card/onboard audio.
Too bad you don't have a S-Video in on your TV. S-Video to Composite adapter cables mix chroma signals with luminance signals causing inferior picture quality. This results in noticeably bad text and colour bleeding in pictures.
Try to connect optical out of your soundcard/onboard audio to your home theatre reciever.
-Keith
there is an option in my home theatre saying that is can beused for game sync mixing. it also has an front av input. so does it hasanything to do with this topic
