. Please Help me. I have a P4 computer with Intel board. I have installed windows XP operating system. The issue, the windows xp hangs as soon as it boots and enters the first screen. I have tried installing the Windows 2000 os also, same result. I have formatted my hard drive and also repartitioned but off no help. I am not able to figure out what is wrong?
yes.try to update your bios, then check your heatsink assembly, check the temperatures at startups...as winxp is more visually implicit,it's highly possible that ur cpu may be hotter than b4...if it overheats...remove, apply good thermal paste, fix it again, and look for fan operate normally.
I am sorry for not getting back. I checked the fan and plast was no longer there. i applied a new thermoplast and along with it an extra fan. For now it seems to be working fine. Thank you all. I really appreciate the time you took to help me out.
