Old 10-07-2005, 12:03 AM   #1 (permalink)
dhawald's Avatar
Default how to save a web page with images
i am using opera 8
i am not able to save a page with the images through 'save as'
though there was an option for saving with images in the older version.
the latest version is missing that option and 'save as' does not help me.
so please help me.
dhawald is offline
Old 10-07-2005, 12:40 AM   #2 (permalink)
Here no problem... I am also using Opera 8 (Build 7561)..in WinXP prof I am able to save webpage with images...its better to reinstall your opera once again...i wish you it may solve your problem.
Cheers
ramakrishna.nalla is offline
Old 10-07-2005, 01:11 AM   #3 (permalink)
bang bang!
Chirag's Avatar
reinstall it.
Chirag is offline
Old 10-07-2005, 01:48 AM   #4 (permalink)
Thor's Avatar
u mean save as type : html with images option is not there ? That is ODD!!
Opera's feature of saving Web pages is inferior to that of IE. [Don't mistake me, I use Opera Myself and is an avid fan !]
IE can save Web pages as .mht archives and as well as .html file. Advantage is that IE places all necessary files in a folder [named same as that of html file + "_files" ] except the html file [which is just outside the folder]
This feature made organizing downloaded webpages easier in IE than in Opera.
@indyan
the software in the forum link has wierd fonts! Can't understand anything.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 10-07-2005, 08:49 AM   #5 (permalink)
expertno.1's Avatar
man click on file
save as
save type as html with images
and u r done
i am using version 8
expertno.1 is offline
Old 10-07-2005, 09:08 AM   #6 (permalink)
dhawald's Avatar
Default problem solved
Originally Posted by expertno.1
man click on file
save as
and u r done
thanks expertno.1
it worked twas so simple
though 'opera' dev have got it wrong as save with images is not a file type.
dhawald is offline
Old 10-07-2005, 09:46 AM   #7 (permalink)
expertno.1's Avatar
its "save as type" and not "save type as"
it will definetly save all urs html images and texts
i use opera 8.01 final
