Old 09-07-2005, 11:06 PM   #1 (permalink)
rajat22's Avatar
Default Ghosty CDW drive
My CDW drive (LG) started behaving ghosty. It is coming out and going in at its will. Any remedy?
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 09-07-2005, 11:13 PM   #2 (permalink)
abhishekkulkarni's Avatar
Oh never heard that problem before.
Please mention your Drive manufac,specs,rig specs and whether u did anything unusual with ur drive ?
BTW: Is it a samsung one ?
May the source be with you ..
abhishekkulkarni is offline
Old 10-07-2005, 12:37 AM   #3 (permalink)
Thor's Avatar
he said it is from LG. And u still ask. !!
BTW I got samsung CD-RW [sw240B] Occasionally this drive also POPs out Whimsically!
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 10-07-2005, 01:32 AM   #4 (permalink)
Oh guess I didn't see that....
Anyways an LG drive doing that sort of thing.Anything can happen thse days...
Old 10-07-2005, 02:00 AM   #5 (permalink)
bang bang!
Chirag's Avatar
It must be a virus. Same prob. there was with my frnd. He scanned the pc a found the virus(forgot the name). SO scan ur pc.
Chirag is offline
Old 10-07-2005, 08:15 AM   #6 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
I think its a hardware problem. my friend had the same problem in his samsung cd writer.. better contact your vendor....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 10-07-2005, 09:48 AM   #7 (permalink)
expertno.1's Avatar
how colud that be
if its not working contatc the service center and for now remove the wire by opening the cabinet
expertno.1 is offline
Old 10-07-2005, 10:02 AM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
I have the same drive Bay problem... with my SAMSUNG DVD rom SD616E......
Choto Cheeta is offline
Old 10-07-2005, 12:20 PM   #9 (permalink)
expertno.1's Avatar
@saurav plz tell frankly that u have the problem!!
coz many ppl on this forum only post i have this or that problem to increase their posts and in actual they dont have that problem
Old 10-07-2005, 02:17 PM   #10 (permalink)
Thor's Avatar
@ ALL
It is probably not a virus , coz I hv done a Full System Scan with Latest Avast! 4.6 HE Defs and found none. Somebody who is hving the problem , cud u kindly check with KAV and let us Know ?
TIA
Thor is offline
Old 10-07-2005, 02:38 PM   #11 (permalink)
Rebooting
expart.... at the time of BOOt up the CDROM ejects it self.... & will not going to close.... no matter how many times u close it.... the drive bay will just opens up.... after few mins (20 to 30) of working...... the problems sloves..... but to my utter surprise i find this time the The drive bay dont get open.... no matter how many times i open it... the bay closes it self.....
this problem happens some time.... some time the drive functions well..... some time i can work whole day without facing this problem.... some times this problem happens strait in full weak....
1st i thought may b this is vzq of heat.... but my other drive... which is LG CDRW.... is working fine.... & the problem can happen after the system got a full night rest....
thought i might take it to service center.... but this happens eregulary..... so still waiting for the exact reson........
Old 11-07-2005, 07:43 AM   #12 (permalink)
rajat22's Avatar
Now it is boxing with me
Where should I get LG service at Kolkata Any idea??
rajat22 is offline
Old 11-07-2005, 09:00 AM   #13 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
From what i've seen it can be two things:
1. A trojan (more likely)
2. There is something preventing the drive from opening or closing properly. Problem with the tray. Get it checked.
kalpik is offline
Old 11-07-2005, 12:05 PM   #14 (permalink)
rajat22's Avatar
Thank you all for the interest shown by you in this matter.
I have solved the problem with some unusual method
Contacted LG and was told by them as a 'motor problem' which need to be replaced at a cost around 800 Rs ,without warranty. Also advised to purchase a new drive.
Online virus & trojan checkups did not solve.
So with utter frustation, I also went for a literal kick boxing with it :roll:
To my surprise, it started behaving normally after a literal kick except I had to isert the tray manually
rajat22 is offline
Old 11-07-2005, 07:54 PM   #15 (permalink)
Laughing ....
Shocked to see LG get a kick in the as*.
Old 11-07-2005, 09:33 PM   #16 (permalink)
Default It is a spyware,run MS antispyware immediately.
Urgently,run a spyware scan(MS antispyware beta) and I bet you will get rid of it immediately,promise because I to got same problem and did the same thing.
Narasimha
K.R.L.Narasimha is offline
Old 12-07-2005, 04:14 PM   #17 (permalink)
i too have this problem with my samsung dvd drive,while my samsung dvdrw dont have any issues. BUT, this phenomenen is not constant and regulaar, sometimes the drive comes out by itself..and if we close, it goes in normaly...this happens once in 25 times, so i have no issues with it..Well this ought to be a h/w issue, as i am damn sure that my pc dont have any viruses / trojan / spyware kinda stuff...first i have 2 firewalls installed, ms antispyware , and KAV..all test results are clean..
it seems , samsungs are prone to this kind of weired ideas.....!!
Rajeev V Nair
premrajeev is offline
Old 12-07-2005, 05:33 PM   #18 (permalink)
check the slaves/ master jack, if it is plugged into slave chord and the it in master jack (behing cd-rw drive) then this might happen. also, check if there is any problems in drivers.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 13-07-2005, 10:40 AM   #19 (permalink)
ALL connections and jumper settings are correct,and cable settings and all.no drivers needed for any cd/dvd drive in windows o/s as o/s loads them automatically.
Rajeev V Nair
