Old 09-07-2005, 05:03 PM   #1 (permalink)
Default No UnInstall after bad Install .....
I installed the demo of Star Wars E1:TPM, but it does not install completely. I cannot even uninstall. Which is the best CleanUp utility I can use to clean this and other messes up.
megacoolxs signing off .....
megacoolxs is offline
Old 09-07-2005, 05:10 PM   #2 (permalink)
expertno.1's Avatar
use system mechanic 5
expertno.1 is offline
Old 09-07-2005, 07:15 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
use 'absolute uninstaller'. also search for the relevant folders/files and delete them physicaly. incidentally, it also has a junk file remover which u can also use. it also has a registry cleaner which u shud use to clean up ur residual invalid entries.
as mentioned above u can also use system mechanic or u can try tne-up utilities .
all will be avlbl at www.download.com.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-07-2005, 07:24 PM   #4 (permalink)
Just Do It
Charley's Avatar
QuarterDeck uninstaller is also really gud, try that.
Have u tried the uninstaller option in CCLeaner new version?
Charley is offline
