Old 09-07-2005, 12:55 PM   #1 (permalink)
ionicsachin's Avatar
Default SEVERE PROBLEM urgent help pleeeez
When i am starting my windows xp it is loading perfectly but while loadind notification it is givig a windows :-
The system has recovered from a serious error
A log of this error ha been created
For more infoemation click here
When i click another window is coming sayin:-
Error signature
BCCode : a BCP1 : 82758C9C BCP2 : 00000002 BCP3 :00000000
BCP4 : 804F1D8C OSVer : 5_1_2600 SP : 2_0 Product : 256_1
To view technical information about error report, Click here
On clicking i get this:-
The following files will be included in this error report:
C:\DOCUME~1\SAchinMJ\LOCALS~1\Temp\WER67a4.dir00\M ini061105-01.dmp
C:\DOCUME~1\SAchinMJ\LOCALS~1\Temp\WER67a4.dir00\s ysdata.xml
Pleeeeeeeeeeeeeez help somebody
ionicsachin is offline
Old 09-07-2005, 01:39 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
It is alright if it came just once. Usually a software conflict. And as the message says, the system HAS recovered! But if it is coming every time u restart, then its a problem. Try un-installing any recent software or driver or hardware u might have installed.
kalpik is offline
Old 09-07-2005, 02:20 PM   #3 (permalink)
if this message is frequent , u should better format ur drive and reinstall XP.
sysdata.xml is related to severe software conflicts and corruption of files.
raasm287 is offline
Old 09-07-2005, 07:52 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
run ur anti-virus and anti-spy and also use tune-up utilities from www.download.com.
such a thing happens to me also sometimes. disable error reporting using tune-up utilities and check the option there 'automatically restart' and dont show error msgs'. its there somewhere. dont panic, microsoft treats all windows errors as serious ! only if u face operational problems, shud u think of reformatting !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-07-2005, 10:29 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
well do u have made any recent hardware/software change??
& do u have SP2 installed?? if not get it installed....
or download this patch..... from MS, installed it...
& do another thing.... recr8 the page file..... follow bellow
  1. Click Start.
  2. Right-click My Computer
  3. Click Properties
  4. On the Advanced tab, in the Performance section, click Settings
  5. In the Virtual Memory section, click Change.
  6. For Paging file size for selected drive, click No Paging File, and then click Set.
  7. Click Yes
  8. nest System Managed Size
  9. Click OK for few times, and then restart the computer when you are prompted
hope this will slove ur problem....
read more here
Get back with the result
Choto Cheeta is offline
