Old 08-07-2005, 10:11 PM   #1 (permalink)
Default converting dvd into cds
hey i have 1000 mb dvd game and i want to burn it and it does not come in one cd so i want to divide it into two cds so that when i install the game from setup.exe it should ask for second cd and i can install my game.any body know the solution then give here
it will be appreciated.
willrock is offline
Old 09-07-2005, 05:21 AM   #2 (permalink)
q3_abhi's Avatar
Well,u can do one thing. Use a file splitter n then divide it to 500 MB each. The only thing is that u will have to burn the software(file splitter)also. While installing,first merge the contents of two CD's on a harddrive using the same file splitter n then continue with ur installation.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 09-07-2005, 04:20 PM   #3 (permalink)
expertno.1's Avatar
there is no need to dispair
use
winrar ..it wil do for u
expertno.1 is offline
