Here is the way.
1. Start IrfanView
2. Go to File > Batch Conversion / Rename
3. Browse to the directory, select all the wallpapers you want to resize and click Add button.
4. Click the radio button Batch Conversion
5. Enable checkmark Use Advanced Options.
6. Click Set Advanced Options button
7. enable RESEIZE and enter 800 and 600
8. Click OK and then Start
Other options you can easily figure out yourself
Hope this Helps
[color=navy]
A geek is someone who remembers his IP, but not his phone number.
[/color]
