Old 07-07-2005, 08:03 PM   #1 (permalink)
Default Copy protecting DATA CDs
Hi friends,
can anyone tell me how to copy protect my CD-R/Ws tht no one can make another copy of it?
I want to make my CDs copy protected because sometimes i burn some confindential data.
any help??
debopriyo is offline
Old 07-07-2005, 08:14 PM   #2 (permalink)
siriusb's Avatar
Copy protecting your cd won't prevent others from reading it. I think u need encryption.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 07-07-2005, 08:38 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I am not able to find the correct thread for this.. I am sure it has been discussed many times in here b4. Search for it
drgrudge is offline
Old 08-07-2005, 12:30 AM   #4 (permalink)
yeah dere is a copy protect discussion i had started... take this link:
http://www.thinkdigit.com/forum/viewtopic.php?t=18231
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 08-07-2005, 02:05 PM   #5 (permalink)
hack expert's Avatar
i have not read the older discussion but here is one solution
try cd lock
CD-Lock secures your removable media by scrambling the filenames and encrypting all the files with Blowfish. Yet, just enter the password when the CD is inserted into any computer running Win2000 or XP and you can instantly use the files as you always have¹ - without the need to decrypt them first.
Transparent Encryption tm
CD-Lock decrypts the files and unscrambles the names quickly and transparently, behind the scenes, so you don't have to. This allows anyone to keep their CD data secure but to effortlessly access their files instantly just by entering their password when the CD is inserted.
Works great on most removable media!
CD-Lock works great on floppy disks, CDs, DVDs, USB flash drives, etc
Link
http://cd-lock.com/
only prob that it is shareware otherwise it is excellent work amazingly
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 08-07-2005, 02:19 PM   #6 (permalink)
alib_i's Avatar
yes .. if you burn confidential data .. then encrypting CD content can also be a good idea
CD-Lock is a wonderful software to do that .. It creates a full folder which you can directly burn to a cd.. and the folder contains the unlock.exe file .. you dont need CD-Lock installed in the system you're trying to decrypt the files .. you just need the password
i've been using CD-Lock for some time .. but i think a still better software ( lesser bugs, etc ) is CryptCD. most of the features are same .. you can try both and decide to buy one.
http://www.cryptcd.com/
PS: its a shareware too
alibi
-Metallica
alib_i is offline
Old 08-07-2005, 04:26 PM   #7 (permalink)
Friends, thnx for the help.
Let me tryout the softwares u recomended.
