Old 13-09-2004, 12:03 PM   #1 (permalink)
Default HARDWARE SUPPORT REQUIRED ! can u DIG it ???
My hdd works as fine as nething when i connect it to my friends PC ( boots,loads os,wors properly)
But when i connect to my System - compaq 7000 presario
Problem:
Case1:
my bios detects my hdd as 10 gb or 40 gb sometimes
next step no operating system found on any drives
Case2:
if i use a bootable it says couldnt register
(it states the reson as follows:
1. non-dos fat
2. third party partion manager used
3. virus attack)
Fdisk
error reading fixed drive
Case4:
knoppix
i:couldnt mount
what i could do to help troubleshoot:
changed the data cables , changed the bios battery.
fixbmr,fixboot
formatted in my system as well as my friends pc
can u diagnos it n tell me what the problem could be ???
suhas_sm is offline
Old 14-09-2004, 10:23 AM   #2 (permalink)
Any help would b appreciated ! some one ! ne one! ne sugestions ?????
me in a desperatre situation now :roll:
suhas_sm is offline
Old 17-09-2004, 01:51 AM   #3 (permalink)
sidewinder's Avatar
Almost same happened with me!!!!! I had to change my bios.Get ur mobo checked quickly.And if the repairing cost is too high go 4 a new mobo.Good luck!
sidewinder is offline
Old 18-09-2004, 12:52 AM   #4 (permalink)
u need to upgrade your computers bios , thats the bottom line !
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 18-09-2004, 10:40 AM   #5 (permalink)
well i think the prob is with primary disk controller... well that means my mobo
suhas_sm is offline
Old 25-09-2004, 10:47 PM   #6 (permalink)
check cables , switch ide on m/b ie, from IDE 1 to IDE 2 , change jumbers to cable select . Try detecting them in the bios . connect without a cdrom or slave . try manufacturers disk fitness test . u can check smart status of the disk that way and run short or long surface test through it . most HDD have ontrack disk manager , so u can backup mbr too . try removing any other components like usb devices , nic etc . Some hdd have limitation jumpers . check that out . try connecting both cd/hdd on same cable , on ide 1 and ide2
klinux is offline
