Old 07-07-2005, 03:10 PM   #1 (permalink)
Default construct & function
difference b/w construct and function
Think about it!
Trinity is offline
Old 08-07-2005, 07:10 AM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
r u talking about programming languages?
if yes, constructs r the various features provided by the language as tools to make a program
while function is one such construct provided by procedural languages such as C.
for more info PM me.
~Phenom~ is offline
Old 08-07-2005, 08:39 AM   #3 (permalink)
abhishekkulkarni's Avatar
Functions
A function in C can perform a particular task, and supports the concept of modular programming design techniques.
The main body of a C program, identified by the keyword main, and enclosed by the left and right braces is a function. It is called by the operating system when the program is loaded, and when terminated, returns to the operating system.
Functions have a basic structure. Their format is:
return_ data_type function name (arguments, arguments)
data _type _declarations of arguments;
function body
It is worth noting that a return data type is assumed to be of type int unless otherwise specified.
This permits type checking by utilizing function prototypes to inform the compiler of the type and number of parameters a function accepts. When calling a function, this information is used to perform the type and parameter checking.
To call a function, it is only necessary to write its name. The code associated with the function is executed at this point in the program. When the function terminates, execution begins with the statement which follows the function name.
Constructors
Objects generally need to initialize variables or assign dynamic memory during their process of creation to become totally operative and to avoid returning unexpected values during their execution.
A class can include a special function: a constructor, which can be declared by naming a member function with the same name as the class. This constructor function will be called automatically when a new instance of the class is created (when declaring a new object or allocating an object of that class) and only then.
May the source be with you ..
abhishekkulkarni is offline
Old 08-07-2005, 11:31 AM   #4 (permalink)
anomit's Avatar
@abhishekkulkarni: Man, change ur avatar. How many times should I tell u??
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 08-07-2005, 08:52 PM   #5 (permalink)
Boy - o' Boy two users with the same avtaar.
Guess this is the first time this has happened in this forum.
So tell you what give me a good reason & I will surely change it.
Now don't say that you had it before I had , coz I got this avtaar by Googling hard for it. 8)
Old 09-07-2005, 10:59 AM   #6 (permalink)
anomit's Avatar
No, this isnt the first time. Previously another user had it. I requested him and he removed it. This is general courtesy. I dont know if its available by googling, but I got it from a friend at AntiOnline
anomit is offline
Old 09-07-2005, 04:05 PM   #7 (permalink)
expertno.1's Avatar
u can get good avatars on www.hotavatars.com
www.avatarity.com
expertno.1 is offline
Old 09-07-2005, 11:06 PM   #8 (permalink)
@anomit
Avtaar changed.
Old 10-07-2005, 01:25 PM   #9 (permalink)
anomit's Avatar
Excellent man!!!Sorry we went little bit off-topic but he has already answered it.
anomit is offline
Old 10-07-2005, 02:26 PM   #10 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
The questions have been answered and the thread is going wildly off-topic, hence locked.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
