Old 07-07-2005, 01:24 PM   #1 (permalink)
whoopy_whale's Avatar
Default Random number in ASP
I tried to generate a random number using the following code.
set util=Server.CreateObject("MSWC.Tools")
num=abs(util.random)
But I get the following error.
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/jobinbasani123/picgallery.asp, line 14
Invalid ProgID. For additional information specific to this message please visit the Microsoft Online Support site located at: http://www.microsoft.com/contentredirect.asp.
Is there any other method to generate a random number?
I have a database and the generated number should be less than or equal to the total number of the records in the database.
please help.....
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 08-07-2005, 12:28 AM   #2 (permalink)
Yeah there is a easy way to generate a random no.
Go thro my foll code and you can easily understand it.
Dim Random_Number_Min, Random_Number_Max, Random_Number
Randomize
Random_Number_Min = 1
Random_Number_Max = 49
Random_Number = Int(((Random_Number_Max-Random_Number_Min+1) * Rnd) + Random_Number_Min)
Response.Write(Random_Number)
Response.Write("")
Response.Write("-")
Response.Write("")
N pls switch to PHP. ASP n microsoft sux!
Njoy coding!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 08-07-2005, 11:26 AM   #3 (permalink)
Thanx Aseem,it works now....planning to move on to PHP.
